[SOLVED] Strange issues with FF Creator Pro toolhead jogging
Posted: Tue Aug 08, 2017 1:41 pm
Hi All,
I am suffering some strange issue with the Machine Control Panel. I am using a FF Creator Pro 2015.
If I select tool head 0 then everything works as expected.
If i select tool head 1, things go weird when on manual control:
X, Y, Z does not move in the selected size step, they move a large set amount.
X,Y,Z does not pay any attention to the speed control, moving very quickly instead
Extruder does not extrude if the x-axis is not at home, the carriage will move along using the extrude button until it hits home, then it will start extruding.
