CptanPanic
How to insert command after 1st layer?
I would like to add a "M117 Text..." command after the first layer. How can I do this?
Thanks.
Re: How to insert command after 1st layer?
Have a read of this thread: viewtopic.php?f=23&t=5128&p=33199&hilit=replace#p33199
Its about inserting a pause at a certain point......and what you want is very similar to what is explained there, but obviously the replaced code in the instruction is different.
brian442
Yup, there's lots of threads about this stuff already (good info here too: viewtopic.php?f=8&t=1959)
Probably going to look something like: {REPLACE "; layer 2," "M117 Text\n; layer 2,"}
That puts M117 command right at the end of the first layer (before starting the 2nd layer)
