MasterFuba
Heatbed not working after update
I have a fabrikator 2 mini, wokrked fine so far.
Now i have updated simplify3d to v4 and now my heatbed keeps cold. It worked fine at last print with old sf3d version.
De- and reinstall has not solved, and i am not able to remove printer settings. After reinstall all old settings are there..... I love when full deinstall keep stuff hidden on hdd somewhere....
Temp value B-2500 is visible in log, dont know what B stands for, but temp graph is complete screwed up. Cant see temp. Its all so tini.... Could be my negativ - 2500 value be...?
Import printer settings is where on new version? I can change and save profile but there is no more import button!? Import uncool now so they removed it in sf3d 4.0?
Broken heatbed or is v4 bugy?
Kr d
brian442
Re: Heatbed not working after update
If you want to remove your settings, go to Help > Reset All Settings
If your printer says B-2500, that sounds like there may be a problem with your heatbed. That's not really a valid temperature, so that would explain why it isn't showing up on the temperate plot in the machine control panel
The settings import hasn't moved since v3. It's still at File > Import FFF Profile
