AK_Eric
[SOLVED] Coasting Distance: Has no effect?
I've been using S3D for a number of years now, pretty familiar with it, but I'd never used the 'Coasting Distance' option : Have a bigger nozzle, getting some blobbing a the end of the extrusion that wipe isn't addressing, so I figured I'd try this.
And try I have: Probably 5 different test-cylinders broken into 5 processes each with difference coast settings. And none of them look any different. Tested this in both S3D 3.0 & 4.0. Save factory file, closed/reopend the software, turned the checkbox on\off \ resave etc. It just does, nothing.
Here's a pic of my end results. The nozzle is traveling screen left -> right, so the left side of the zipper coasting should address. I also turn off my fan briefly between sections so they're easier to tell apart. In this case, all the same:
Here's a pic of the gcode: Clearly there should be some gaps forming, since I put some really big values in there (2mm for example):
I did another test with even *bigger* values, still no effect.
Here's my factory file for inspection:
no_coast.factory
(16.59 KiB) Downloaded 730 times
I'm using a custom build core-xy printer with RepRap Firmware runnnig on RADDS, .6mm volcano nozzle & bondtechBMG extruder.
Any thoughts as to why this would be happening? I'll attach my gcode in the next post.
Bots:
Makerbot Replicator 2x / Sailfish on Mightyboard
Custom C-Bot / RepRap Firmware on RADDS
Custom Tevo Little Monster / RepRap Firmware on Duet
AK_Eric
Re: Coasting Distance: Has no effect?
And here's the gcode:
no_coast.gcode
(136.22 KiB) Downloaded 1121 times
Bots:
AK_Eric
Contacted S3D Support: With really big vals, like 5mm and greater, I'm starting to see some effect. Guess I didn't aim big enough to start.
Bots:
nkuck
Re: [SOLVED] Coasting Distance: Has no effect?
Have you been successful in really getting this resolved? I’m up to a coasting value of 16, still with no effects. :x
airscapes
Just curious what artifact coasting is supposed to fix, never used it.. Oh NM layer change..
Too late at night for me to be bothered repeating what can be found elsewhere!
Read these:
viewtopic.php?f=8&t=1980
https://www.simplify3d.com/support/prin ... -and-zits/
And btw.......coasting DOES work. You just need to know what it does first to be able to recognise what it's effect is!
