Version 1.0.7 Now Available
Posted: Thu Apr 04, 2013 8:23 pm
We just finished the final touches on the 1.0.7 update for the Creator software, focusing primarily on improved USB communication. We're also including a few new goodies like support for the 250000 bps baud rate, the ability to save and restore manual support material, and the X/Y offsets that were requested by those using delta-style printers. The complete list of changes are given below.
Thanks for everyone's feedback so far. Let us know what you think of the new update!
- Added experimental support for 250000 baud rate (requires you have appropriate drivers already installed)
- Further optimization to G-Code file size and overhead communication
- Rework of USB serial communication to take full advantage of microcontroller serial cache
- Added automatic reset for older boards (like Gen6 electronics) that do not restart when a new serial connection is initiated
- Emergency stop button has been improved to also restart older boards
- Added new G-Code configuration variable for startup command to better support other firmwares
- Added global X/Y offsets specifically to help with Delta style printers where zero position is at center of table
- Small bug was fixed for bridging calculations with multiple internal cutouts
- Added option to import and export manual support structures
- Factory files also now include support structures in their all-inclusive format
- STL parser has been updated to handle a wider variety of multi-solid files
- Previewer has been updated to better handle relative movements (i.e. jogging)
- Added 10cm lift and X-axis homing to M2 profile ending G-Code (avoids hot nozzle sitting on top of part)
- Manual Support and Cross Section dialogs now stay on top of other windows
- Better handling of out of memory errors for large previews
- Improvements for activation routine
- Improved debugging tools for serial communication
