[ADDED] Loading Via Command Line
Posted: Thu Mar 27, 2014 8:34 am
by joesoap583
In Windows 8, adding Simplify3D to the Start menu means that when you run Simplify3D the operating system automatically builds a list of recently opened factory files, which are accessed via the Start menu option.
Unfortunately, Simplify3D doesn't support command line options - so those links to factory files do not work.
I would therefore like to request that Simplify3D is modified so that a command line specifying a factory file can be supplied.
Furthermore, in most regular applications the File menu contains an option listing the most recently opened files, making it very easy to reload a recently worked on project - without having to navigate thru Windows Explorer to find the file of interest. I would therefore appreciate it if consideration could be given to recently loaded factory files being shown shown in the File menu.
Re: Feature Request: Loading Via Command Line
Posted: Thu Jul 09, 2015 8:38 am
by S3D-Jason
Version 3.0 now includes automatic file associations so that you can easily open a file with the software. This is automatically applied to gcode, stl, and factory files.
Recent file menu was also added in version 3.0
