Dignard
Rotate Part
Able to rotate part on all three axis, not just place surface on table. as a minimal flip axis x, y or z.
brian442
Re: Rotate Part
You can already do this:
https://www.youtube.com/watch?v=moMR90DmzD4
You can also double-click on the part and do it that way too:
https://www.youtube.com/watch?v=i5rLVYpeoXU
lutorm
Re: Rotate Part
One rotation that you can't do, as far as I know, is to find the "lay flat" position when you have a part that does not have a face that marks the down-position. Typical example would be something organic that in its printing position rests on the table at three points. Cura has a function to find the resting angle, but in S3D you have to fiddle with the angles trying to get it right.
brian442
Re: Rotate Part
That's already in the program too (Edit > Place Surface on Bed)
https://www.youtube.com/watch?v=XJi4_ScDLtE
