Weird lines
Posted: Sun Aug 20, 2017 4:26 pm
by zappa79
Does anyone know why I get these weird bandings or what ever they are called?
Re: Weird lines
Posted: Mon Aug 21, 2017 7:19 am
by wirlybird
I think that is the layer stop/start points. You may be able to change the start point setting and see if it makes a difference.
Re: Weird lines
Posted: Mon Aug 21, 2017 7:23 am
by arhi
only one axes? only one wall? or you get them on all axes and all walls?
this looks like a microstepping issue some drivers have at lower speeds so they skip steps, depending on your driver solution vary (if that's the culprit), for drv8xxx you need to add few external diodes, for alegro you need to switch it to "always mixed decay" ..
Re: Weird lines
Posted: Tue Aug 22, 2017 3:28 am
by zappa79
wirlybird wrote:I think that is the layer stop/start points. You may be able to change the start point setting and see if it makes a difference.
Layer start stop?
I am realatively new to 3D printing, would you be so kind to help me out a bit more? how do I do that?
Re: Weird lines
Posted: Tue Aug 22, 2017 4:10 am
In the Settings Layer tab there's a section headed Start Points. The descriptions are self explanatory and if you hover on the radio buttons for a second or two then tooltips will appear that give a little more info.
