Keeping PVA going when its used sparingly
Posted: Tue Aug 29, 2017 6:39 am
I have done some work with soluble supports that was quite successful.
With the latest simplify 3D we can create supports in the normal material and then just add the final layers of the support in PVA.
This sounds great.
However I found the PVA sitting in the heated nozzle degrades unless some PVA is printed regularly.
Is there a way using the existing features in simplify 3D to print a bit of PVA external to the model, on a tower, or an ooze shield or whatever to prevent the degrading - so it will print nicely on the dense layers of my support structure?
I'm not having great success with normal supports. I either get a rough knitted sweater type finish on the supported surfaces, or I get supports that are very difficult or impossible to separate from the part. Supports with some dense layers at the interface were particularly impossible to separate. I was promised with simplify 3D I could get a much improved finish on supported surfaces - but so far I only managed that with soluble supports.
Maybe I can print the supports in a rigid insoluble material that just doesnt stick to my part material? what combinations of materials might work like that?
This sounds great.
