Support Structure Orientation
Posted: Sat Apr 05, 2014 4:06 pm
I'm really starting to like S3D. At first it was a little bit of a fight but the more I use it the more I'm starting to love it!
I'm printing a couple of objects that need support and I was wondering if it's possible to rotate the support structure? Currently I'm having to add in extra support structures to cover the area that I need and it seems like if I could rotate the little block to fit the area that this would be taken care of.
Also as far as supports go I'm noticing that when I set the layer separation to 1 that I occasionally have overhang areas that are not properly supported and they sag. I'm wondering if I set this to 0 will those be difficult to remove? Using a layer separation of 1 makes them easy to remove which is very nice!
Thanks,
Jared
Thanks,
Jared
