Dual nozzle printing, weird first layer prime tower issue.
Posted: Sat Sep 09, 2017 12:16 pm
I setup a print using my FFCP'16 using simply3d 4, I've been using PVA for a little while as a second material, so I am just getting used to this, but I noticed that the first layer, the PVA will print as part of the skirt (both extruders partake), then will prime on the prime tower (only extruder to use prime tower), followed by the PLA extruder doing its whole first layer, then the PVA nozzle finally goes back to its printing.
On subsequent layers this is not the case and the printer will print the prime pillar, then immediately go on to print the PVA parts.
This is causing some issues with the finicky PVA, is there a way to change this easily?
Is this a bug?
Thx.
Is this a bug?
Thx.
