PETG blues (well, yellow)
Posted: Sun Sep 10, 2017 4:38 am
I'm new to 3D printing and slicing, so please be patient with me.
At first, I was just using the PLA profile and adjusting temps for PETG. Of course, the quality of the print was horrible
Then, I learned a bit about the retraction settings and print speed, and thought I was making progress. I got a decent looking calibration cube.
and I went to print an STL file that had a large flat area, with a few tabs on them, and a back that rose up, slowly and on an angle. I got a mess!
i've tried reslicing, reorienting, but for whatever reason, whenever the print gets to this part, it starts to have trouble. The dimensions of that area is pretty thin, so I thought maybe it is the infill, so I increased the # of wall layers, changed infill to 100% and I still got the same type of pattern there.
What is odd is that you can see, part of the print is ok, and then it seems that the extruder just starts to go on the blink.
It takes me a few hours to get to this, so I will try to post more photos. In the meantime, I hope someone might have an idea of what to do next.
RObo3d R2, 0.2mm, Hatchbox PETG. hotend: 255, plate: 65, print speed: tried 1500 mm/min to 2000 mm/min, retraction distance: 5mm, retraction speed 2400 mm/min
thank you for taking the time to read this post.
