I recently purchased a Creality CR-10 and whenever I try to print anything It starts up in the upper left hand corner (Or lower right depending on how you are looking at the printer). The models are centered on S3D before I save the files to my SD card. I've read on some other forums that when the used CURA the set the machine to not zero so it would print in the middle. However I would rather use S3D instead of CURA so I need to figure out how to do the same thing. Any help would be greatly appreciated.
maybe the Size of ur printbed is not the same as in the settings. Double-Klick on your "Profile" go to "G-Code" and look at "Build Volume"
Have u even created a profile? I also have a Creality3D CR-10 and i made my profile like Makers Muse and Press Reset did on youtube.
