Adding Bridge Over Large Area
Posted: Thu Sep 14, 2017 4:28 pm
by JimmyTime
Hi All,
Despite trying to stop it from bridging, the large opening in the middle of my part is getting filled when I slice. It oddly starts on the 2nd or 3rd layer. I've included two screenshots below and the factory file. I sliced a near-identical part earlier in the day with no such problem. I do remember this behavior from about a month ago right after the switch to 4.0, but I just moved along at the time.
https://www.dropbox.com/s/c1datkwo0uikb ... ctory?dl=0
Re: Adding Bridge Over Large Area
Posted: Thu Sep 14, 2017 9:19 pm
You need to run the shape file through one of the online repair services....there are issues in the mesh!
Posted: Fri Sep 15, 2017 8:19 am
by JimmyTime
That was it, repaired online and it slices correctly now.
Thank you! A mesh in need of repair was the absolute last thing on my radar. I did not know how EASY it was for a mesh to get corrupted or have print issues. My usual tool chain is Solidworks > NetFabb Basic > S3D, and the objects I create are relatively simple. All I did in NetFabb was slice the part into 3 across some seemingly solid boundaries.
I will no longer assume a mesh's integrity despite its simple origins. Thanks for the unintended lesson :^)
