I had been having an issue with thin walled prints, where the infill overlap was printing outside of the wall... resulting in a rough "cottage cheese" appearance...
Version 4 resolved this, with changes to the way it handles thin walls (kudos to the devs!!!).
The fix also revealed another issue...
I think this is an example of Y-ringing? The vertical line appears to be an indent on one side of the print and a protrusion on the opposite side. My guess is that I can fix it in the short term by making the wall slightly thicker, but I'd rather correct the problem.
If this is an example of y ringing, would adjusting the acceleration speed help?
thanks for any input & advice;
Lorcoft.
