2.1.0 GPX additional terminal commands not executing
Posted: Fri Apr 11, 2014 9:57 am
by andre
First, I noticed my bot was jamming right from the start. Then, I noticed I can't seem to get my custom terminal commands to execute... anyone else? I have Create x3g ticked. I need these since I run a batch file that launches GPX and some other code for tool changes. Without this, I'm dead in the water.
Re: 2.1.0 GPX additional terminal commands not executing
Posted: Sun Apr 13, 2014 11:13 pm
by andre
Fixed. Had an issue with file permissions. Reinstalled to a different folder (outside of Program Files). Sadly, if the file can't be executed, S3D doesn't give any warning...
Posted: Wed May 07, 2014 1:40 pm
by andre
Grrr.. this problem returned. I rebooted the PC (updated windows with latest service updates). Anyone else having this issue? I have the "Create x3g file" unchecked, and put in gpx.exe in the terminal commands. GPX does not get executed.
Posted: Sat May 10, 2014 12:23 pm
by JoeJ
You probably typed something wrong with your post-processing command. Just test it yourself in the Terminal. Once you get the right command to run GPX, then copy it into the post-processing box
