[SOLVED] Compressed Z height
Posted: Fri Sep 22, 2017 6:33 pm
Sometimes my prints are compressed in z height. Sounds crazy, thats how it looks - strange. That occured since my simplify3d 4.0 upgrade. Heres an image of an x cariage which has a mount for a 4x4cm fan:
Im sure its an firmware bug of my printer and not Simplify3d.
Heres the gcode.
https://expert-craft.com/images/other/s ... tten.gcode
Id loaded it into an gcode viewer to make sure if the complete gcode has an bug. The gcode seems to be correct.
If the z steps/per mm wouldnt be correct, i would have an horrible amount of overextrusion, but i dont....
Fun fact - the z height of the print is divided by two. So its just the 0,75 long in height as it should be. (Exactly 0,75, thats why im confused)
Heres my simplify3d profile
https://expert-craft.com/images/other/s ... sertag.fff
Im a litte bit confused about that bug. The most prints are correct in z height. But some not - like this case....
If someone got suggestions where to search, thanks in advance - youll help a lot!
Heres the gcode.
