In my SD card I have a file named "xxx.g" so after importing my model I generate the GCODE file using S3D. It opens the dialog where I want to save the GCODE file. So I click "xxx.g" and it askes me if I want to replace the filename. SURE, I want! So I click OK. After that when I open my SD card there are 2 files "xxx.g" and "xxx.gcode".
For some reason no matter the extension that I use it will ALWAYS generate a new file with the gcode extension. Even if I type ZZZ.g it still will save the file as ZZZ.gcode.
I really need to save as .g extension cause I use auto0.g files from Marlin and it only accepts .g extension so everytime I save a file using S3D I have to go do my sd card, remove the .g file and after that rename the .gcode file to .g
