Prime Pillar Extrusion Multiplier
Posted: Fri Oct 06, 2017 9:08 am
Hello!
I'm printing a lot with PLA and PETG. They don't stick together very well, so they are the perfect combination for parts that need support.
Prime pillars higher than about 5cm always suffer from delamination, in my case. To solve this problem, a extrusion multiplier for the prime pillar would work very well.
This problem could also be solved by adding a command in the gcode, when a certain feature is completed. Something like:
That way you clould use post processing to get something like:
Adding this would also allow much more features like swithing a special fan on, only when printing a bridge.
Generally speaking, the post processing leaves much to be desired.
Best regards,
Leo
; prime pillar start
G1 X188.001 Y123.083 F6000
G1 Z1.334 F1002
G1 E7.0000 F3600
;prime pillar endCode: Select all
M221 S140
G1 Z1.334 F1002
G1 E7.0000 F3600
;prime pillar end
S221 S100Generally speaking, the post processing leaves much to be desired.
Best regards,
Leo
