2.1.0 Crashes when importing model, Mac Mavericks OS
Posted: Mon Apr 14, 2014 11:53 am
by JSPY
I am new to Simplify 3D, and just bought a Makergear M2. Yesterday I downloaded the latest Simplify 3d and it won't import any models. I have tried to export some from Sketchup (using STL exporter) and tried to download some from Thingiverse.
The program seems to parse triangles, but then just seems to crash without anything showing up on the virtual build plate. I can talk with the makergear OK but can't try to print anything. I have tried restarting my computer, uninstalling Simplify 3D and reinstalling, but nothing is helping. I have the latest version of Mavericks and an Imac which was new as of last December.
Any ideas?
Jason
Re: 2.1.0 Crashes when importing model, Mac Mavericks OS
Posted: Thu Apr 17, 2014 5:31 pm
by JSPY
UPDATE*
I have been getting an error code
std::bad_alloc
This seems to have something to do with ram or memory, but I just got a new Imac in December. I watched the activity monitor when this program crashes and it doesn't come close to running out of memory.
I have also determined that if I uncheck "arrange and center" model in preferences, it doesn't crash but also doesn't show anything on the virtual build plate. I have tried on both my Imacs from different years and running different OSX.
The machine profile I am using is Makergear M2 Vb3
Anyone else ever have this?
Posted: Wed May 07, 2014 5:42 am
by jimmynz
I have this same problem (both of them) with 2.0 and OSX Mavericks get the std::bad_alloc when importing some models. Upgraded to 2.1 and now it just crashes when I open any model. Pretty Disappointed. Seems since 1.1.5 Both 2.01 and 2.1 have had some really annoying Bugs. Suggestions as it is completely useless as it is?
Posted: Wed May 07, 2014 8:13 am
by jimc
Wish i had some some advise to give. I can tell you i have an imac with mavricks and have run every version of s3d since 1.1.5 and i have never seen this.
Posted: Thu May 08, 2014 12:15 am
by jsc
Please link to one STL from thingiverse that always crashes for you.
Posted: Sat May 10, 2014 3:49 am
by baron
+1, have same problem with Mavericks, have contacted support. Waiting for a workaround/solution/update
Posted: Mon May 12, 2014 3:24 am
by KTy
Also first time, crashing exactly as described above... but on Win7 64 !
Had to reboot whole computer
Posted: Fri May 16, 2014 1:00 am
by LeonMF
+1
OSX Mavericks
MBP Retina 2012
I can't even slice as I get a divide by zero error when it tries to save the model.
Posted: Fri May 16, 2014 1:02 am
by LeonMF
I forgot to mention that I managed to import by dragging the stl file onto the build plate. Trying to import the model through the import command crashes.
