Bulk setting change for processes
Posted: Tue Oct 24, 2017 6:11 am
Feature: bulk setting change
It would be nice to be able to change a single or multiple settings for a selection of processes at once. If this is already possible, I apologize for apparently not having read the fine manual well enough
Say I have an object printed using 5 processes. Single extruder, the processes are needed for settings like cooling, speed, infill, and so forth.
Now say I find out that the printing temperature for my filament should be 5 degrees higher.
This will cost an insane amount of clicks. I'd have to first click a process, then the temperature tab, which defaults to the bed, so then I need to click the extruder, and change temperature. Then I'd have to repeat this for the other 4 processes.
So to change only the temperature, say 5 degrees higher, I'd need about at least 15 clicks, and be very carefull I did not miss a process.
Ofcourse this does not only go for temperature. This goes for every change which is universal across all processes.
I can see several ways of going about this. You could make a bulk settings change wizard, in which you just say what setting you want to change, and then which processes you want this change applied to.
The other way is by making it possible to select 2 processes, then edit, and then leave out the stuff which is really process specific (like name, process name, and so on) and let the user edit all common features like speed, temperature, and so on, for all processes at once.
