I'm getting inconsistent results with the following:
Combine Support Every <3> layers
Dense Support Layers <6>
Upper Vertical Separation Layers <1>
The above settings work out fine. I get (2) dense support layers and (1) separation layer. However, when I try:
Upper Vertical Separation Layers <2>
I end up with (1) dense support layer and (4) separation layers.
This is with a layer height of 0.010 if that matters. Does this make any sense? Why can't I get (2) dense support layers and (2) separation layers?
When I do:
Upper Vertical Separation Layers <3>
I get <1> Dense support layer, and <4> upper separation layers... I can't make sense of this...
