Starting gcode
Posted: Mon Oct 30, 2017 10:25 am
I am having problems with the starting gcode.
I have everything setup as i would like. But for some reason this code is at the start of the gcode and is causing me problems.
G1 E-4.5000 F1500
G1 Z0.512 F1500
In my starting script i have :
G28
G1 X15 Y15 F4000 ;move X/Y to front of printer
G1 Z35 F9000 ;move the platform to 35mm
T1
G92 E0 ;zero the extruded length
G1 F300 E30 ;extrude 30 mm of feed stock
G92 E0 ;zero the extruded length again
T0
G1 F4000
G1 X45 Y15 Z15
G1 F9000
Which all works fine. But after it purges the nozzle. It drops right down on the purge and drags it to the print.
The code i posted is the problem. But how do i remove it? Its on the start of all my outputs.
G1 E-4.5000 F1500
G1 Z0.512 F1500
G28
T1
T0
G1 F4000
G1 X45 Y15 Z15
G1 F9000
