Extrusion width for Solid Layer
Posted: Mon Oct 30, 2017 10:49 am
I would like a solid layer extrusion width designation option.
The solid layer has slightly small grooves. In order to make a flat surface for painting, it is necessary to fill the groove with putty. If the extrusion width of the solid layer is made wider, the groove is buried, which makes work very easy.
Thank you.
Thank you.
