Makerbot Keeps Printing Last Model
Posted: Wed Nov 01, 2017 12:21 pm
by jasstohr
I thought I was having sequential print problems but when I switched to a different model, I discovered the printer was just reprinting the last thing that I printed. Simplify3D appears to upload the new file but the printer just restarts the last print. Any ideas?
Re: Makerbot Keeps Printing Last Model
Posted: Wed Nov 01, 2017 2:02 pm
by jasstohr
Ok. So I have restarted the printer which I would think would clear the memory of the last print. The same problem still exists. It's as if Simplify3D is sending the old model instead of the new model. HELP!
Posted: Wed Nov 01, 2017 2:24 pm
I remember that happening to me about four years ago on my Replicator 2. Only problem is, I can't remember what caused it....or what I di to rectify it..if anything! If anything springs to mind....I'll post again.....
Edit....I seem to remember resetting something from within RepligatorG. I don't print via USB nowadays, so can't rummage around all the bits in RepG. as there's no printer detected.
Posted: Wed Nov 01, 2017 4:04 pm
by jasstohr
Ok. So identified the issue as a problem with the Default Process. I have been using custom processes for quite some time and went back to using the Default just for kicks. Apparently my Default process has a different setup using different scripts than my custom ones that I developed a while back. I never customized my scripts so I am not sure why they are different. Do I just need to uninstall Simplify and reinstall as a fresh instance and reselect my printer setup to get the codes to be the correct ones again? I can't change Default.
Posted: Thu Nov 02, 2017 6:25 am
by wirlybird
Before uninstalling I would try going to the help menu and select the reset to factory (or something like that) and after that completes then go through the setup to add the printer.
