Measurements
Posted: Tue Nov 07, 2017 4:30 pm
by cmccullough
I would like to see a way to make quick measurements on the model to verify the scaling.
Re: Measurements
Posted: Wed Nov 08, 2017 3:54 am
by brian442
Sometime I use a lot - if you double-click on the part, it will show you the XYZ dimensions on the right-hand side. So if you ever want to verify how big a part is, that's another quick way to do it
Re: Measurements
Posted: Thu Nov 09, 2017 6:10 pm
by dadamisin
+1. Great idea..
Re: Measurements
Posted: Thu Nov 09, 2017 6:55 pm
by Calvin.kim207
Totally agreed!
Not so much for the overall size of the model (that you can verify by double-clicking the model) but actual measure function between faces, lines and vertices.
A lot of times I want to measure the thin wall thickness to make sure it's not too thin (this may also determine how many perimeters i should have), measure the distance from the build platform to the overhang/bridging, measure distance between 2 parts for sequencial printing so there are enough space to clear the printhead and the list goes on and on and on!
