Single Nozzle, Dual Extrusion
Posted: Thu Nov 09, 2017 12:11 am
I've recently finished up a new printer build, with a North Five TC-01 extruder. It's a dual extruder, similar to an E3D Cyclops. For the life of me, I can't seem to get retraction and restart settings correct. I can do it manually, but to do it automatically is beyond me.
Currently, as S3D doesn't properly handle Single Nozzle type dual extrusion, I the second extruder set to T5, and use a post-process replacement to change that to T0. Not a big deal, works reliably.
To do a filament change, I have to retract the current filament 40-45mm, and then extrude the new filament 55-60mm to purge the old color, and that's what's proving to be impossible. I also need to do the initial priming - ensuring that both sides of the hotend are loaded as they need to be.
Any suggestions for getting it to work?
