Variable settings wizard caps out at 5mm
Posted: Sat Nov 11, 2017 3:07 pm
by thedbp
Hi
I'm trying to do this:https://www.youtube.com/watch?v=N-7uX6Dw-7Atest in simplify3d instead of cura. but while my model is 100mm tall, the variable settings wizard caps out at 5mm but I want to decrease the temperature for every 5mm so I need it to go all the way to 100mm, anyone know why it wont go past 5mm?
Re: Variable settings wizard caps out at 5mm
Posted: Sun Nov 12, 2017 1:32 pm
by brian442
I am guessing that your "ABS test-1" process is also limited to only go from 0 to 5mm, so when you vary the settings within that process, they also can only go to 5mm max.
To fix it, double-click on that process, go to the Advanced tab, and disable the "stop printing at height" options (which I assume is currently set to 5mm)
Posted: Mon Nov 13, 2017 3:33 pm
by bjarchi
+1 to this reply.
If you started this factory file from a previous file that used a split process, or in some cases if you've been recently using a split process, the 'stop printing after x mm' setting can get propagated into your modified (or even new) factory. This confounded me for a while as well.
