Dual Extrusion Confusion
Posted: Mon Nov 13, 2017 7:47 pm
Please simplify Dual Extrusion. There seem to be many points of confusion and inconsistencies.
In the Dual Extrusion Wizard you select which model is printed in which color by which extruder. Two subprocesses are created under a master process. Points of confusion.
- Why is the master process even editable? I assumed anything edited there applied to both. No. Not true.
- When editing one of the subprocesses for a color, why are both extruders shown? One is already assigned to that color. Can I change the properties of the other exturder? Or am I reassigning which extruder to use? It's not clear.
- Or additions, temperatures -- I can set either extruder's properties from either color's process?
- But not support? To edit support, I have to be in the specific color's process?
This is a bit of a mess. It's too easy to make a mistake. Can it be streamlined?
