Multi Size Supports
Posted: Thu Nov 16, 2017 9:06 pm
by vangalvin
It would be really nice to be able to add various size supports even better if this was set up in the auto generate.
Ideally supports on angles would be AWESOME however for the moment I generate a bunch of larger supports at around 3mm then go in a add some 1mm supports to areas where they are needed. The down side of this is that if I decided to regenerate the 3mm supports all the user added supports vanish.
