Perimeter shell overlap on shallow slopes
Posted: Sat Dec 09, 2017 9:22 am
by bnorman
I've been printing legs for the Vorpal Combat Hexapod (https://www.thingiverse.com/thing:2513566). They have a region with a shallow slope, and I've noticed that is the weakest part of the print. Most of the legs broke here when trying to remove the print from the raft. I think it's because the layers are offset by about one extrusion width, so with 2 perimeter shells, there's really only about one shell of overlap. Is there a way to tweak this behavior in Simplify3D (other than just adding more shells)?
Thanks!
Re: Perimeter shell overlap on shallow slopes
Posted: Sun Dec 10, 2017 3:59 am
by rrdavis
You can increase the number of top or bottom solid layers, since that would also add more solid fill near those steep overhangs
Posted: Sun Dec 10, 2017 4:07 am
This is one of the uses of the variable settings feature: https://www.simplify3d.com/support/arti ... f-a-model/
Simply divide the model using the wizard....and then increase the number of perimeters where you have need due to the angle of the outside surface.
Posted: Sat Dec 16, 2017 3:17 pm
by bnorman
Both good ideas; thanks!
