Go directly to startpoint of the skirt at the start
Posted: Mon Jan 01, 2018 11:43 am
by JuKu
My printer drools a bit of plastic when it heats up. At the start of the print, S3D takes the head to the origin, drops the drooling there, prints the skirt and tries to start the print, which is ruined because of the drool. My current workaround is to wait until the head is almost at the start temperature and sweep it off manually with a piece of filament. It is easy get distracted and besides, this shouldn't be needed. Please make the head go down to the start position of the skirt, so that the drool gets dropped outside of the workpiece,
Re: Go directly to startpoint of the skirt at the start
Posted: Tue Jan 02, 2018 4:06 am
by rrdavis
You can edit your starting script to do this. Or you could even add an extra wipe movement if you wanted to automatically remove the drool.
