1132/5000
Hello
I'm having a problem with printing a single extrusion piece.
The coin is a cigarette pack case with 0.5mm walls.
When printing with PLA the angles are just glued.
In FLEX only one on the four corners is correctly glued.
The other three are not attached.
If I print in FLEX a piece without angles also in single extrusion walls of 0.5mm as for example a case of lighter all is well.
From the surface aspect I'm slightly over-extruded so it's not a% flow problem.
My extruder can work well with retractation on FLEX but I did not allow it to slicing
The four sides of the case are well printed, so I have no problem temperature.
My printer allows a setting of the Jerk but even with the lowest value, instead of having a surplus of material, a vacuum is created at the junction of the faces ...
The case being printed in vase mode for PLA, I also tried without this mode for the FLEX with always the absence of junction ...
I do not understand what is happening and do not know what to do.
Thank you for your answers
