So I've got a print that for some reason it seems the wall is not actually bonded to the floor next to it. The odd thing is if I print it with this feature pointing down instead of up it doesn't occur however given the design that is not a good way to print this object. With that said, is there something I can modify/change withing simplify3D to mitigate this? I am printing on 1.75mm PLA w/ a maker select. Given everything is equal but the orientation I'm not sure my print speed/etc. are worth mentioning. Looking at the layer it seems that there is no overlap between the wall and the infill there but it looks like there is in the one pic w/ it facing up, or maybe it just flowed together due to gravity?
This is the object printed facing down w/ support
This is the object printed facing up
Tool path on this layer
