Cannot open file to read
Posted: Sun Jan 21, 2018 9:28 pm
by markeys
Having an issue with any files I try to print in where I get an error code Cannot open file to read. Printer is a New XYZ Davinci 1.0 AIO
Re: Cannot open file to read
Posted: Mon Jan 22, 2018 4:48 am
by horst.w
Without any information about the problem and what you have acted for getting a result it is hard to have an opinion to your problem.
But I guess it could be about the same or similar problem, take part to this thread:
https://forum.simplify3d.com/viewtopic. ... 767#p38767
Regards
GER
Posted: Mon Mar 19, 2018 9:09 am
by dibble
I've been having this issue as well with XYZ 2.0A Duo.
@horst There's not a lot of troubleshooting you can do. It typically happens to me with larger files.
I find that to get the printer to work at all I have to perform a certain dance.
1. reboot printer
2. unplug USB from computer
3. launch S3D
4. plug in USB cable to printer
5. open a model/position/process preview
6. open machine panel and manually connect (it defaults to bluetooth for some reason--I need to manually select USB)
7. once the machine control panel is communicating with the printer (communication tab will live post printer state)
8. go back to the preview window and click print
Even doing all of that, I can only reliably print small files--like a test disc of 1cm x 3mm. Printing larger files will be a 1:5 crapshoot. Sometimes just repeating the process above works. If it fails more than 3 times in a row I can sometimes reboot the whole setup--computer/ printer and get it to run. But, it is not reliable.
Posted: Sat Nov 03, 2018 12:56 am
by MasterCATZ
Upgraded to ver 4 and now this keeps happening spent 2 hrs power cycling / restarting / reloading before it would work on ubuntu ....
