[BUG] Crash on multiple process/multiple model sequential
Posted: Tue Jan 23, 2018 1:03 pm
by Bassna
I was trying to set up a few small files, each with their own separate processes (2 processes per model) and sequential printing. When slicing, S3D crashes. It does not crash when doing continuous printing.
Re: [BUG] Crash on multiple process/multiple model sequentia
Posted: Wed Jan 24, 2018 3:40 am
by horst.w
You have forgotten to attache the factory-file.
Without this, nobody can help.
Regards
GER
Re: [BUG] Crash on multiple process/multiple model sequential
Posted: Thu Mar 22, 2018 11:00 pm
by StafDehat
I'm seeing the same symptoms myself. Here's my environment info, and the factory file is attached:
wumpus ~ # cat /etc/issue
Linux Mint 17.2 Rafaela \n \l
wumpus ~ # uname -a
Linux wumpus 3.16.0-38-generic #52~14.04.1-Ubuntu SMP Fri May 8 09:43:57 UTC 2015 x86_64 x86_64 x86_64 GNU/Linux
wumpus ~ #
Running version 4.0.1 of Simplify3d.
Posted: Fri Mar 23, 2018 5:35 am
by rrdavis
Slices fine for me in 4.0.1. Maybe try going back to the website and re-downloading the latest installer.
Posted: Sat Mar 24, 2018 5:55 am
by horst.w
Slicing, for me too.
But the settings for sequential printing are realy faulty!!!
Some FFF are bound to models twice, three times and more.
However the FFFs are different to the others there is now start / stop in the Advanced tabs. It is strongly recommended to begin with much more easy to print models as stand alone.
Regards
Posted: Sun Apr 29, 2018 4:26 pm
by gloda
I am experiencing similar problems. I have attached the factory file I am trying to slice.
string(2).factory
(33.04 KiB) Downloaded 235 times
S3D also crashes for me when I try slicing the file posted by StafDehat.
Simplify3D 4.0.1
MacOS High Sierra 10.13.4 (iMac) and 10.12.6 (MacBook) – the crash happens on both machines.
I have tried rrdavis' suggestion to re-download and re-install. This has not solved the problem.
I should note that the MacBook managed to slice the file once. When I left Preview Mode and sliced the file again it crashed once more.
