Hello,
its me.
I found out that when you set the retraction distance to 0,00, the retraction vertical lift will not occur in the g-code. I wonder if I can disable that, so I only have the retraction vertical lift without the retraction distance.
If I had to put some retraction distance, what is the minimum value that I could actually give in before the software ignores it ?
Best regards,
Stephen
