Dense Support Questions
Posted: Thu Jan 25, 2018 11:36 am
I'm new to S3D and have been reading a lot about support structures. But I still have some questions.
1) Is it possible to specify Dense Support Layers per individual supports? Or must that setting apply to the entire print?
2) If I specify 3 Dense Support Layers, S3D prints these both on the top AND the bottom of the support. I do not want/need them on the bottom - only on the top. How do I do that?
3) If I Specify Dense Infill Percentage as 100% and Upper Vertical Separation Layer = 0, is that essentially the same as bonding the support directly to the print?
4) What I'm trying to do is improve the quality on the underside of my print where the supports attach. Is there a way to essentially build a raft on top of the supports?
Thanks.
Thanks.
