S3D stops working when prepairing to print ANY stl
Posted: Fri Jan 26, 2018 7:29 am
by MarkNotts
I have not got a corrupted file, I even made a simple box 20x20x5 just 6 faces to make sure it was not triangle count.
I hit the button to prepair to print and it comes up " SIMPLI~1.EXE has stopped working " , it has been fine since I installed about 2 weeks ago, version is the latest 4.0.1, system is windows 10 64bit.
I have uninstalled and reinstalled twice, 2nd time uninstalling the licence aswel then running winaso registery cleaner to fix any system errors, when loading it still has all the presets I made and the last model so something is not uninstalling, what do I have to do to get this softwre to work again?
Re: S3D stops working when prepairing to print ANY stl
Posted: Fri Jan 26, 2018 8:54 am
by rrdavis
You might want to send the S3D people an email with the crash log, computer details, etc. This sounds like a pretty odd issue, so they will probably be able to help more.
Posted: Sun Jan 28, 2018 12:14 am
by MarkNotts
ok thanks rrdavis, hpw do I get a crashlog from s3d or is it a windows crashlog ?
Posted: Sun Jan 28, 2018 2:59 am
by horst.w
Do you have uninstalled as described here
https://www.simplify3d.com/support/faq/#faq-4604
or over Windows functions what is not sufficient?
Regards
GER
Posted: Sun Jan 28, 2018 3:41 am
by rrdavis
MarkNotts wrote:ok thanks rrdavis, hpw do I get a crashlog from s3d or is it a windows crashlog ?
Just use the standard windows event viewer to find the crash log
