Feature request: Profile inheritance
Posted: Sun Feb 04, 2018 9:18 am
I'm printing test cubes with modified profiles at different heights, and finding it would be useful if there could be a base profile and then modified profiles that inherited settings from the base profile. In this way you could have modified profiles that changed a parameter such as outline speed reduction every 5mm, and then to run the same test at a different temperature, just the base profile would be edited. Profile settings could have knowledge of whether they had been changed or should inherit, similar to visual studio property sheets.
