dkreitz0
Enable Parameter Printout
I would be great to be able to print out the advanced build parameters in order to document changes when fine tuning setups. At present, the only way to do this is to print a series of screen images.
rrdavis
Re: Enable Parameter Printout
Pretty sure you can already do this by going to File > Export FFF Profile. That exports all of your settings to an XML file which you can easily compare in a text editor.
