How is inner perimeter speed calculated?
Posted: Wed Feb 14, 2018 6:19 pm
My default speed is 100mm/s, outline is 60% (60mm/s) and solid is also 60% (60mm/s). Support is at 80%, perhaps it is just halfing the difference between outline and default print speeds and adding it to inner wall speed?
Looking at my gcode at layer 2 (Taking 1st layer variables out of it) I'm at the following:
layer2
inner 80 Does this use the support speed variable or perhaps halfing the difference as stated above??
outer 60 Correctly matches my defined speed
solid 60 correctly matches my defined speed
Thanks
Dave
layer2
Thanks
Dave
