gabrielebrugnoni
Above support speed
Hello.
I'm using Simplify3D with a Cetus3D printer.
Objects made with S3D have the support difficult to remove.
To avoid that the first layer on top of the support is melted with the support,
it would be useful to be able to decrease the printing speed, so that the fan cools the material better.
A parameter "Above Raft speed" like the one in the Additions/Raft would be useful.
Support made with the original Cetus SW are very easy to remove.
I have not been able to find a Simplify3d setting that can make a kind of easy to remove support like the Cetus software.
Thank you.
Gabriele.
gabrielebrugnoni
Re: Above support speed
Hello again,
maybe i've found a solution using bridge parameters.
I've slow down to 20% the bridge speed, this generates a bridge above the top support at slow speed.
Bye.
Gabriele.
