Feature Request - Custom Command Panel
Posted: Wed Feb 21, 2018 3:43 am
I've asked about this before in emails to Support, with no response, so hence this post. Why is the Custom Commands Panel only about 3 customisable macros, I could use a lot more, and this feature is enabled in Printer Host, Matter Control & Print Run too.
For example, some printers don't need 4 SD card buttons, and I don't have a Disable Motors function either, so this area is wasted, and I could use this to add extra functionality. I cannot be the only one.
You could even have drop downs for SD card functions from an common SD card button, likewise toggle motors on or off.
Anybody else like to see this expanded.
Another little 2ยข, is it possible to have a GCode window in the Jog Controls Tab, I've got around this by using two Macros, so that the extrusion controls work with one of my "supported" printers
