What setting is responsible?
Posted: Wed Feb 21, 2018 2:28 pm
So I recently printed a cone-shaped surface, about 1mm thick, and you can see the result below. The part of it without the tabs printed cleanly, but the layers with the tabs (they'll be used to hold the piece in place) are very rough. I'm guessing it under-extruded on those layers on the outside perimeter, I would just like to understand why and if there's a setting I need to change.
I'm using a Delta printer (Rostock), printed in Alloy 910 with the filament in a dehydrator keeping it under 10% humidity.
I'm also including a screenshot of my Advanced Tab, as I think the Thin Wall Behavior best applies.
