First layer help?
Posted: Sat Mar 03, 2018 6:52 pm
by 3DEnthusiast
My first layer settings are
67% layer height
150% layer width
60% speed
The rest is set at
.2 layer height
80mm/s speed
There are still gaps in the first layer but those are the best settings as anything else results in a feathered looking first layer. What am I missing?
Thanks!
Re: First layer help?
Posted: Sat Mar 03, 2018 6:56 pm
by Willy83
Hi, forst of I'm a starter in the 3d printing world but perhaps my settings help you out.
First layer settings:
120% layer height
120% layer width
50% speed
.2 layer height
60mm/s speed
Good luck
Posted: Sun Mar 04, 2018 5:49 pm
by zemlin
If your first layer isn't packing quite as much as you like, it's a bed height issue, not first layer settings. The slicer will compensate the paths it lays down according to your settings, so going wider means it will spread the beads further out, not close up any caps you're seeing.
reduce the gap between your print nozzle and the bed to tighten up the first layer print. Don't go too far though or you'll end up flaring the part at the bed.
Posted: Sun Mar 04, 2018 9:48 pm
by 3DEnthusiast
Thanks guys!
My bed uses a proximity probe and auto-leveling so I will have to add it to the Z offset. I'll give that a go and see if that fixes my issues.
Posted: Sun Mar 04, 2018 11:40 pm
by Gencab
3DEnthusiast wrote: ↑Sun Mar 04, 2018 9:48 pm Thanks guys!
What printer are you using ?
Posted: Mon Mar 05, 2018 5:14 pm
by Aha
Definitely try z offset as a significant thing. But you might be underextruding as well if it is stringing or not finishing the top of some. You can up the extrusion multiplier.
Do let us know how you come along, I've been having that problem suddenly and I'm also not sure how to fix it as it is not z-offset in my case I'm pretty sure.
Posted: Tue Mar 13, 2018 5:46 pm
by 3DEnthusiast
I'm using an i3 clone I built. The Z-offset seemed to resolve the issue really well.
Thanks!
