jhafel
Incorrect Scaling
Hello,
I cannot seem to get this figured out, but I have a perfect 20x20x10mm box that I am using to make sure the scale is correct, but when it prints the measurements are 19.82x20.46x10.01. I finally got the height correct, but I don't understand what would cause one side to be too short and the other too long. The quality guide has been a great help, but I don't see anything that discusses this kind of stretching.
I am using an Anycubic Kossel Linear Plus and the material is PLA.
Thanks for ant help!
Re: Incorrect Scaling
The printer is calibrated correctly?
Use one of the calibrate-models of thingiverse.com to controle it, i.e. https://www.thingiverse.com/thing:2551272
If the printer is calibrated and 100 mm are not 100 mm extruded (more or minor) then please attache your gcode-file.
To clarify what happens it is helpfull to use a non quadratic object and to turn it 90° and see if the issue is static or turns with the axis.
If the issue is stable, then X / Y steps are not right.
To calibrate a Delta-printer is not easy!
Regards
GER
