The application was unable to start correctly (0xc000007b).
Posted: Tue Apr 22, 2014 3:04 pm
by rixpix247
Help... :( That is the error code I get right after a clean install and double clicking on the icon to start. I would really like to get Simplify3D working so I can use it to print on my new MakerGear M2.
Thanks in advance for the help!
Re: The application was unable to start correctly (0xc000007
Posted: Tue Apr 22, 2014 8:51 pm
by jimc
im not sure what that error code is. if i was you i would email support on this.....unless someone here has seen this before and has a quick answer. did you try uninstalling, getting a fresh download and installing again?
Posted: Thu Apr 24, 2014 6:05 pm
by rixpix247
Yah, uninstalled, reinstalled ditto etc., AND decided to go with the 32 bit ver as a temp fix until I get an answer from Simplify3D tech support. The support hasn't happened yet. :( Will try the direct X and opengl drivers when I get a chance, but for now the 32 bit did work for a while... and then broke...
So, I need to find where the file that keeps the previous user/file settings resides and delete it. It does not get uninstalled with the uninstaller, so when I reinstall, I still have the previous settings and I want to go back to a clean slate since that state printed great. Now I am just printing (don't understand why) in the lower left half inch corner for an object that is 6" long and 3" wide and 1.75 tall, and yes the scale is correct and the viewer shows it at the correct size/scale. Really confused and frustrated now. Glicthy software has been my experience so far. Not good. :(
Posted: Fri Apr 25, 2014 10:28 am
by 3Drasle
Did you solve the problem?
It might be that you installed a 64bit prg on a 32bit system.
/Michael
