steveps3
Vary setting by height
Currently you can use the variable settings wizard to vary a setting at discreet height changes. Id like a feature whereby a setting scales from value A to value B over a height range. So you could do a smooth transition from a low infill to a high infill or you could do a temperature test with a scalte of temperatures that gradually increase as the height increases.
