Removing tiny infill
Posted: Mon Mar 26, 2018 2:24 pm
Hello,
I'm hoping someone has a quick answer for this problem. I've sliced a part, and I'm getting very small bits of infill, and I can't figure out how to remove them.. My minimum infill length is set to 3.00mm, yet these are still showing up. Not sure where else in the settings I would remove these. They slow the print time significantly. And, because I'm running a bowden set up, there's the retraction and wipe for every single one of these, it makes the whole print process much more cumbersome...
See attached image.Any help would be greatly appreciated.
Thank you in advance,
